Just wondering if anyone has some suggestions for a workaround for this major bug.
I’m working on the latest firmware and studio - 2.6.20.627
Any external surfaces on the left side of the print simply don’t bond to the infill. There’s about a 0.2mm gap between the infil and the wall surface, which results in every print failing. This only happens on this side of the print, and I’ve checked the sample prints by Tiertime and theirs seems to exhibit the same fault.
Looking at the infill, it seems “squashed” to one side, as though there’s an error in the firmware that causes it to miss the wall completely.
There is no value in infill at all if it doesn’t connect with the external walls, which are already way too thin.
It would be better if several layers of external wall could be selected, and then have infill bond to this, but this isn’t possible.
I’ve been told that earlier versions of Studio don’t have this problem, however cannot downgrade due to firmware incompatability.
Can anyone advise a fix schedule or workaround? And if it’s a downgraded version of studio, please advise which firmware should be loaded to support it as Tiertime don’t seem to record studio/firmware matching information on their site.
David
