Hi
Does anyone know where I can get the STL for the Tiertime UP300 ABS head shroud? Mine has broken due to the switching knob being very thin, and catching inside when I switch from head-airflow to bypass.
Is there a STL we can download and print to replace the shroud when it breaks?
David
I’ll give it a shot in PLA and then switch to ABS if that doesn’t work. I’m curious as to how thin it will print, since the original seems thinner in places than the UP300 should allow.
