The thermistor on the heated bed of my UP300 is reading about 10 degree C to low. This means that when print ABS the actual bed temperature is lower than necessary and causes prints to warp.
Is there a method in to calibrate or adjust the thermistor reading in the Tiertime software?
There is no way to calibrate the heaters on any Tiertime printers.
If you are convinced the bed or the nozzle is cooler than indicated in the software, I would suggest creating a custom material profile and bump up the temperatures in there.
Thankyou Jimmy. That is what I have done but thought I would ask on the off chance Tiertime might have implemented an obvious thing such as this.
