Hi, what can I do to reset the software because the Up Plus 2 printer seems to stop at the same spot on different models?
This is just a wild guess as I don’t have an Up Plus 2 (I have the Up Box+), my suspicion is that it is to do with the on board storage either being corrupted or full. There doesn’t seem to be much information on re-formatting or replacing the SD card, but I would think that would be a good place to start.
Thanks. But my Up Plus 2 uses a USB cable instead of an SD card. Search continues.
You use a USB cable to send the sliced data, then it is stored on an SD card on the motherboard. I would try to format it or replace it with another one.
Also, the hotend heater can be ‘‘dying’’.
That’s an idea. How do I reformat the motherboard? Thanks.
