i have a problem with UP Mini 2 ES. Extruder is skipping only on the left side of a bed.
You can clearly see that on this clip. Only few cm along the table is wrong.
and yt: https://www.youtube.com/watch?v=D8NwkRJW3W8
Thank you!
Thank you!
Check extruder cable, or replace extruder cable.
I have replaced the extruder cable and that solved the problem,
Thank you!
