If anyone is interested, I just posted a new spool holder extension at Thingverse for the Box and Box+ printers, https://www.thingiverse.com/thing:4299899
            thanks i need this im gonna try them and see what happens :d
After some time using this Up Box+ Spool Extender, I came to realize that it was not stable enough to hold full 1kg spools without tipping slightly on the mounting. This was mostly due to the fact that the snap tabs on the Up Box+ spool holder do not have actual 90 degree snap engagement. I have redesigned the Spool Extension to have two more positive alignment points that keep it firmly attached and aligned at all times. It is still able to be removed if necessary, but snaps firmly in place when in use. The new file is Box+ Spool Extender 1.STL I left the original spool extender file so you can see the differences.
