I have bought eSun PLA+ cold white filament. Tried to extrude it at 215 deg. C. and I’m getting an occasional skip from the extruder motor. It extrudes smoothly at 230 deg. C., not less.
When attempting to actually print something the raft usually starts OK; however, it looks like the material is not extruded in a constant rate. After a while the motor starts to click and I stop the print.
What do you think is causing this?
I have had no issues with any material so far.
Machine is an MKII upgraded to MKIII.
