Trouble toggling laser pins on MK3
Hello everyone,
Recently got the Cetus3D MK3. I am trying to figure out how to toggle the external laser pins as shown here
From what I can understand is that these two following gcode commands should toggle the pins:
Laser Off Command: M42 P15 S0
Laser Print Command: M42 P15 S1
When I upload a .gcode file containing the laser off command using UPStudio, the pin stays HIGH. (Measuring with a multimeter gives contant 5 Volts)
Is this guide outdated or am I missing something?
Thanks for reading
The functions should be still there as we did not change anything (I suppose). I will confirm with the production see any change in electronics may affect the function.
The function is still there, confirmed with the development team.
Marco Reps has made a vido about using a laser by Cetus:
Really cool mod, well done!
