Thermal expansion
How do you conteract the effect of expansion when printing parts?  I have printed objects that should fit or hold everyday objects (votive candle, for example) only to find the final result has a too small hole for the candle to fit.  Is there a setting to help counteract it?
That shouldn't be an issue.
Check out this Maker's Muse video about tolerances. Unless you're sizing components and/or openings /really/ close, you should have no problems (as the shrinkage for most materials is negligible).
https://www.youtube.com/watch?v=TYuLVN3YHw8
What material are you using?
Just standard PLA.
I will give the tolerence guage a try.
Before you even try that, how tight are you setting your design tolerances? I can't imagine that the physical tolerances of a votive candle are all that well controlled...
The good thing about candles is that they are made of wax. Soft wax. Easily carved or melted, if you get my drift!
I have had slightly oversized parts and saw this video: https://youtu.be/TFsTo6cDmF8.
That is why I was asking how one could counteract it on the Cetus.
