A strange extrusion issue has occurred and we can’t resolve it.
Issue:
On the front left hand side of the board the extrusion stops and makes a shuddering motion when you feel the filament. The board is flat and calibrated and the nozzle is the correct distance above the board.
If you extrude the filament before printing it extrudes fine. If you print a model on the right rear, left rear, or front right of the perf board it prints fine. If you try to print on the front left quadrant no filament comes out and the shuddering of the filament begins.
We have tried:
Complete new extrusion assembly but this has the same issue;
Checked all the cables and ribbons are on correctly in case it pulls a lose connection on the ribbon when it is at maximum distance;
new filament;
-recalibrated the bed and checked that the nozzle doesn’t go too close to the board;
-reinstalled the software.
I have attached two pictures. The first is the on the first time it went wrong. You can see that it has printed perfectly for a while, and then all of a sudden it has stopped extruding filament in one area of the print bed. Everywhere else is fine.
The second picture shows that it prints fine everywhere on the board, except for the front left quadrant. We printed a big square and when it reaches the front left quadrant it stops extruding, but when it moves back to one of the other areas it starts extruding again.
Any ideas of what to try next?
