Slicer Issues
[quote][size=2][color=#999999]Bln post at 2017-2-26 12:21[/color][/size]
@chieffly, I am Also a 3d printer newby and I am having the same rsults. No rsponse from Cetus yet, …[/quote]
Hey. I got acceptable results using 0.4 nozzle and layer thickness 0.07, filling 99% (I did not try it less, but maybe it will work too). Then the surface is smooth. One minus. Very frequent support and poorly separated.
Hi guys,
Which layer heights are you using?
I believe this is an underextrusion issue.
I checked this with different layer heights. I have this issue with 0.1 mm setting. 0.15, 0.07, 0.2 are working fine.
A possibility to change the extrusion factor would be helpful at least.
Shay 2017-5-4 05:53 edit
I am new to 3D Printing and Cetus3d is great!
Unfortunately I have a issue with the bottom and top layer as well. It's rough.
You can see the lines.
Anyone have answer on this issue? Are there any settings you can recommend I try? Or a test print that has settings for the Cetus3d you can recommend?
Thank you.
