Acidemaleique 2017-2-15 13:03 edit
Hello here,
As said in the title, I have 2 problems.
The first one is an extrusion problem.
During last week, I printed multiple things with the 3 types of nozzles (0.2, 0.4, 0.6 mm).
Some of them worked correctly, but with the 3 nozzles, I had problems : during the printing, at different times (it could be after 30 minutes, or after 40 hours for the last), my Cetus began to make some "toc", slowly (one "toc" every 10 seconds) or quickly (as if someone knocked at the door). What's more, even if the Cetus continued to do his job, the filament didn't go down, or verry little.
I tried to extrude in the maintenance mode (to check if the nozzles were clogged), the "toc" was again here, but the filament went down well.
After that, I resumed the printing, and it was the same as before the maintenance mode : nothing or very little.
So, do you have any idea of what isn't going well ?
The second one is a problem with the software : last time I wanted to stop the printing, I pushed the "stop" button, but the printer didn't stop. Whereas, the software considered the printing was stopped (the interface of the software was like if the printer stopped, and it didn't suggest me resuming the print). After something like 10 minutes, the printer freezed, and it'is impossible to resume the printing. So, my 40 hours printing isn't finished ...
So, is it possible to resume / begin a new print from a X layer, to finish this print ?
