Problem with wireless disconnecting during job upload
I’ve been having issues with my Box+ of late. Often when I load a file into Up Studio once I go to print the file it slices then sends to the printer over wireless. However often times especially on large files the connection to the printer drops and an error appears on the screen. Often Ill have to reset the slicer and then try multiple times to get a successful upload.
What is happening?
I’m using a Mac with software 2.5 installed.
Same, I wonder if there is a way of improving the aerial ?
If the problem is wireless signal quality then just get a repeater; but the wireless seems to be deeply flawed, at least in my printer. I’ve had partial success telling my computer to continuously ping the printer before and while using UpStudio. Once the latency drops down to less than 100ms the performance seems to stabilize (and stay stable while the pring is running) - could be worth trying.
C:\>ping -t upmini
Pinging upmini.lan [10.10.0.6] with 32 bytes of data:
Reply from 10.10.0.229: Destination host unreachable.
Reply from 10.10.0.6: bytes=32 time=1008ms TTL=255
Reply from 10.10.0.6: bytes=32 time=242ms TTL=255
Reply from 10.10.0.6: bytes=32 time=261ms TTL=255
Reply from 10.10.0.6: bytes=32 time=283ms TTL=255
Reply from 10.10.0.6: bytes=32 time=93ms TTL=255
Reply from 10.10.0.6: bytes=32 time=8ms TTL=255
Reply from 10.10.0.6: bytes=32 time=4ms TTL=255
Reply from 10.10.0.6: bytes=32 time=2ms TTL=255
