Hello, I own Cetus 3d MK2 without mods witch worked great. After some time I got weird set of problems, let me explain what I get:
- Raft is printed in a perfect condition.
- A layer before the main object print is printed with printer ticking/clogging/hammering sounds, with feeder having a trouble feeding the filament
- The print is printed same as detailed as before but without ticking/clogging/hammering sounds. However, the layer thickness is smaller than desired.
My settings
Thickness: 0.5
Width: 0.2
Nozzle diameter: 0.4
Quality: normal
Temp: around 225
Easy to peel
I have tried cleaning the nozzle, aligning the bed, changing temperatures, different models, sample models, different filaments, making sure filament is rotating freely.
By the way, Upstudio 2 did not take temperature changes well - it was crashing quite a lot. I solved it by making new profiles.
Please take a look below
- YouTube
Any advice is welcome.
