PETG Support
Can we get support fo PETG? At the moment for most of my prints the Cetus software puts in additinal supports even with the option disabled. This makes it impossible for me to print with PETG as you cannot easily remove these supports. Other than that the PETG prints perfect.
i always use petg and the supports removes without any efforts, sure isn't the quality of the filament? i have only problems with abs-pc in that case the support stuck with the part
Do you need a heated bed?
I also print PETG and had no issue to remove the support. I'm using "Das Filament" filament, which is a german manufacturer.
