If I copy a model then the printed rafts will overlap and lead to problems.
I can't see the rafts in the editor, so there is no way to check this before printing.
How can I make one big raft instead of overlapping small ones?
you can merge the models before printing so that the raft will also merge.
[quote][size=2][color=#999999]JasonWu post at 2017-10-30 07:58[/color][/size]
you can merge the models before printing so that the raft will also merge.[/quote]
Hi Jason
OK I will try to find that option.
This should be done automatically, right?
Best Regards!
Chris
You made a point, this add to our feature request list. Thank you!
If you just add the same model to the print bed numerous times (rather than duplicating)then there is no problem with the rafts overlapping. May take a little longer but better end results
