Even though the heater temperature has dropped during printing, it is still measuring a high temperature, so the heater does not operate and cools down, causing the nozzle to become clogged and printing to fail.
Also, even though the heater temperature is normal, it may detect a high temperature and issue a “nozzle temperature too hot” error.
The timing varies, and if you’re lucky, you may be able to print without any problems.
However, there seems to be a problem with the control and correction of the temperature sensor.
The bed also has a heater and sensor, but their behavior is clearly different from that of the nozzle. It seems that the nozzle sensor reading response is slow.
It seems like the problem is with the circuit, not the heater or sensor.
I suspect that the capacitor has deteriorated.
I will fix it myself, so please give me the UPBOX circuit diagram manual.
Hi, can’t find a circuit diagram but did you ever fix the problem? I just got a practically brand next upbox plus but there seems to be heating issues. When preheating it climbs to the correct temp but then cannot maintain it even when no filament is being loaded but still says it’s at the correct temperature. For example it goes to 220c measures at 220 then drops to 160 and displays at 220.
Hi have you got any further with this issue? It seems to be common but I’ve not found a quick/cheap fix. I’ve checked the ribbon cables as advised by Tiertime but there are no shorts. Works occasionally but then it says 400degC when switched on and room temperature. Our UpBox has had very little use.
I had a similar issue in the plus 2. They use the same head. The cables or rather the connection to the RTD sensor fail and when it gets hot they disconnect showing a very high temperature while when cold they connection is restored. It gets progressively worse. A new print head should solve the issue. Alternativity it is a break int he ribbon but the RTD connection in the print head seem more likely to me. Good luck.
Hi, I have not gotten any further but have been looking into and experimenting with different thermocouples. Tiertime doesn’t include a model for the thermocouple but eventually I should fine one for under $5. Otherwise you can buy a new head for around $100 (which I do not recommend) or find just the heater and thermocouple together for $20. The parts are cheaper on AliExpress. One thing to note is that the thermocouple and heater are held in by ceramic so it may be hard to remove/replace the thermocouple and heater. Overall I believe that tiertime products are just not worth the time. Instead I recommend you buy and elegoo printer. The Neptune 3 pro is around $150 and is an amazing printer with cheap replacement parts while the tiertime printers for me have been a money pit. The tiertime software is also pretty bad.
Yes, I believe the RTD is the issue. A break in wiring should exhibit more regular temperatures throughout the heating process or have a more unpredictable reading. The problem is that for the amount it would cost to experiment theory’s I can buy a much better printer.
