No Matching Parameters and red triangle always ON
I succeed to print wuth Studio 3, but still the message " No Matching Parametrs" and red triangle is on. How could I remove the message?
If you are using default materials, the software will auto match setting for you. However if you change main setting eg layer thickness, and the software found no preset profile for the particular layer height, then the software will give this message.
Currently preset profile coverage is quite narrow, anything other than 0.4 nozzle at 0.2mm layer may trigger this message.
If think it is annoying then define a new material and open up all main setting, the software stop auto match.
