Paul,
I've added my email address to the spread sheet - how do I pay you?
Paul,
[quote][size=2][color=#999999]cmeyer post at 2017-5-7 18:03[/color][/size]
You may also want to check out Maddie's solution: http://www.thingiverse.com/thing:2265920& …[/quote]
I tried Maddie's solution and everything assembled well. I used the 20oz spring version. Had to recalibrate the Cetus, but now I have the following issue: The prints are completely fused to the raft. I print with the same filament as before the mod, standard factory settings, with raft. The raft comes off the plate pleasantly easy, as before. The difference is that the print is completely fused to the raft, to the point that if pulled with pliers, it rips the entire part. I recalibrated several times (9 point) and tried all sorts of nozzle offsets, positive (really flat raft layer) and negative (really wavy raft layer), it does not seem to affect it at all. I'm not sure what I'm doing wrong. If I take the spring device down and put the printer back to factory default, it prints perfect, part separates easy. Not sure why this is happening and what I'm doing wrong?
My kit arrived today and was promptly fitted. Works a charm ! It was a bit unnerving putting self tapping screws into the printed bits of the Cetus3D but it all worked ok. Ran a simple print of a box following installation just to prove all OK and it was :)
