Still with some prelimary parts (printer still prints on it's own housing), but already fully functional with inner lamps, HEPA (14) and activated carbon filtered air.
Sweet! :D
This is almost exactly what I'm planning to build. Acrylic enclosure with corner fixtures, and, for ventillation, a 120 or 140mm Noctua fan running the air through carbon and HEPA filters.
Nice Job! It looks good! :D
That looks great! Do you have any details about the parts you used and mount for your filter? Is the suction from the fan enough to not need a bottom enclosure?
The filter box is from another design I haven't released now (would require some modifications before). Everything except the filters (of course) is just part of my design and 3D printed. The HEPA H14 filter is from a Nilfisk vaccum cleaner wich is available on Amazon for 13 Euros.
Enclosing the printer completely is not a good idea! The Cetus extruder does not like higher ambient temps (will stop extruding) and a completely enclosed printer will heat up such an enclosure quick (even quicker if the heated bed is used). Higher chamber temps would need a modification of the extruder (much more cooling of the cold end).
Another point you mentioned: The suction. No I think the suction with the first fan was not enough, switched to a much stronger fan now. And if there is so much suction needed (wich I think it is), how could this work with a completely enclosed printer? That's why the bottom is open (creates a chimney style air vent with the filter box). Another point is the easy access to the printer (the new design has a magnetic front that can be detached and the printer pulled out).
I will finally test the filter box with special smoke/powder visually (don't have a particle tester :-)
Right now there is zero smell in the room, only a bit noticeable with the nose directly above the fan.
New design version: https://www.cetus3d.com/index.php?r=moshop/info&id=2325
Nice work!
