Mounting heated bed
hi everyone.
Do you have tried to mount the heated bed ? (If you have it!!)
This one heat. But print never stick in it....
Even with raft... after 3 or 4 layers, raft unstick....
We may have to put the coated bed upon the heated bed?
But what screws do I need? I don't have it....
Other idea?
Thanks!
The heated bed needs a cover on it, you can use buildtak or something similar or just painters tape if you want.  I use the printinz and it works well.
Or you can put coated bed on top of heated one, works perfectly.
Yes.
That's what I do.
(With rubber band for oven cooking!)
But I loose 1cm at each side.
I want to use screws.
What size do you use?
Thanks!
I'm now using the normal coated bed on top of the heated bed. You do need longer screws to fix this. I tried to use other methods of adhesion, but found the original coated bed to be much better. I bought a set of 10mm length M3 screws at the local DIY shop.
Regards,
Bas.
M3 x12 are better.
Tried 10 ones but unscrew after few printed parts removing....
Great info.  Thanks guys.
