[quote][size=2][color=#999999]cmeyer post at 2017-8-2 14:14[/color][/size]
If you click on "featured" at the top of the forums you'll find a thread on setting up slic3r an …[/quote]
If you get reproducible motion system errors with S3D sliced gcode while prints sliced with Cetus Studio run error free you did not all and it is the problem (otherwise better get in contact with TT support).
Double check the manual steps required for the S3D setup (see Jasons documentation), especially the init commands (scripts) and the twisted axis settings (gcode). I did not check the new version (S3D 4) yet, but the V3 versions run fine with my two extended Ceti.
