Is it possible to use microswitch endstops with the Mk2 printer ?
If not will a Mk2 motherboard with microswitches fitted work with Mk3 firmware ?
If you use microswitch to MK2, you should remove the extension PCB on the limit switch socket on the mainboard, also you need to flash ROM to MK1 version.
