Manual Temp Settings
While there are presets for ABS and PLA in UPSTUDIO, I can’t seem to find how to manually set nozzle/bed temps. This option is probably right in front of me, but I can’t seem to locate it. A little nudge in the right direction would be appreciated.
Thanks!
You go to Maintenance, click on material type, at the bottom you click on Customized.
In the next window you can choose Edit and add a profile based on for example the ABS profile.
You can change a lot of things but be sure you check that it counts for all the nozzle and layers settings you will use.
Thanks for the help. Much appreciated!
