Laser engraving
Hi Cetus Team,
Is there any talking about the laser engraving?
I have the laser device is ready as attached, can you please tell me how to connect it to cetus?
I have external power supply ready as well...
Is there any tutorial?
Best Regaeds
Zaghloul
The closest I've seen would be this: https://www.kickstarter.com/projects/854865943/cetus3d-at-199-get-all-you-need-to-start-3d-printi/posts/1695215
There's an accessory port socket underneath the white extruder cover that's empty. In theory, the M42 P15 S0/S1 commands should be toggling that on/off, but in my testing the power remained on constantly. Hopefully just a software bug.
Zezo_khaled 2017-5-6 08:27 edit
I need to know how to connect the laser device to cetus electrically via TTL?
the laser specs as below
Power Max.3.5W , Average 2W
Wavelength 445nm-450nm
Luminous color Blue
Focus Yes, the minimum focus <0.5mm
Input voltage DC 12V
Current > 2A
TTL Yes, low level (0V): OFF, high level (5V): ON.
Frequency 0-20KHz
So if I'm reading your laser's specs correctly, it needs to be powered by 12V. That means you would need an external power supply, since the Cetus provides 5V on the accessory ports (besides which, I don't think those ports could source enough amps to power the laser anyway).
On the bright side, the accessory port does supply 5V, which according to your spec above is what the TTL control of your laser needs, so that sounds like it would be perfect.
As I've mentioned before, we'll have to wait on Cetus to disclose what's happening with turning on/off that pin, though, since it doesn't seem to work with the command mentioned in the update I've linked above.
As for the actual connection, I think (but am not positive), that it's a JST-EH connector. But be careful, there's some places selling what they call JST-EH which is clearly not, so look at it before buying. I've been able to repurpose an R/C receiver servo plug to fit, though the pin-out is different.
The connector I'm talking about is under the white cover on top of your extruder. The one on the right side in the attached image.
Im able to connect it now, the problem is the smplify3d cant detect the cetus port
Software 1.2.1
The Cetus (and its UP siblings) don't natively speak gcode, which is what S3D outputs. So you'll need to generate your gcode file w/ S3D and then load that gcode file into Cetus Studio for printing. There's a thread talking about S3D and another talking about Cura on these forums.
can you guide me to how this thread how it works or to artical show me how to make it work via the cetus studio?
apprectiating your efforts
The article they wrote: https://www.kickstarter.com/projects/854865943/cetus3d-at-199-get-all-you-need-to-start-3d-printi/posts/1695215 has an example for how you can use a third party program to generate gcode.
Once you have a gcode file, you click the + button in Cetus Studio and select the gcode file to run it.
But please read and understand this thread first: https://www.cetus3d.com/community/forum.php?mod=viewthread&tid=272
In particular the parts about the coordinate system, offsets, etc.
Please also review the gcode file before running it, especially the first few lines of movements, to make sure you've got the coordinate system & nozzle offset correct.
This is very little information to give an answer, which model of laser engraver you have, which brand. There are characteristics of absolutely different types of such devices Perhaps you will find something similar to yours and will be able to understand how to connect it. Look, they are all completely different.
Hi Zezo_khaled
How did your project went with the laser?
Does it work well for you?
I’m planning to do some similar upgrades as well and I was wondering if you could share what kind of laser you use, how you connected it to the printer, how you was able to turn the laser on and of using TTL. Maybe some G-code.
Hope you would help me
//T
Unfortunately the link to thread 272 is faulty, does anybody know how to reach this content?
Thanks to everybody in advance!
