Is this raft correct?
jene 2017-6-5 02:47 edit
Excuse me, I have a question.
when I print 0.05 or 0.07 mm,  the raft always become torsion like the picture.
but I think that the raft should be more straight.
is this picture correct?
I have never finished printing 0.05mm.
I want your help.
It looks like the height is set wrong - that's a typical raft where there is too much space between the nozzle and the build plate.
[quote][size=2][color=#999999]Coop42 post at 2017-6-5 17:42[/color][/size]
It looks like the height is set wrong - that's a typical raft where there is too much space betw …[/quote]
hello, Coop42.
advice thank you!
I will try to check the nozzle height. thank you.
jene 2017-6-6 10:26 edit
as a result,
I found that it could be "no raft" better than "set raft"  when I print with 0.05mm.
as a test, I checked "no raft".  it was able to finish.
especially, her ear didn't need support. Cetus3D has a great potential. I'm glad.
Thank you for taking your time responding to my question.
That looks like one of the best prints I've seen.
jene 2017-6-7 03:01 edit
[quote][size=2][url=forum.php?mod=redirect&goto=findpost&pid=1671&ptid=329][color=#999999]pauland post at 2017-6-6 16:50[/color][/url][/size] That looks like one of the best prints I've seen.[/quote]
hello, pauland.
comment thank you !
I have thought that the raft need definitely. but,  it is not necessarily in small resolution.
It's a blind spot.
and usually, the bottom rough layer is not easy to remove.
but, it is a little easy to clean compared with big resolution.   after I removed the rough layer, a clean layer appeared. good.
