I’ve ordered a heated build plate for my Cetus and after installing it. It doesnt seem to work as intended. Sure it heats up. But no temp control. No feedback about the temps, nothing. In the UP studio software, next to the nozzle temp, there is an another temperature, but it shows constantly about room temperature. I’m guessing this should be the plate’s temp. In the maintenance menu, I can give any temp for the plate, but it doesn’t seem to have any effect on the temp. And I can’t choose any print board option, only the “Coated build plate”.
Is this normal or is my heated plate defective?
Also that heat insulation layer at the bottom makes terrible noises while sliding on the linear guide… and you cant even print on it, you need to coat it with something. I’m a bit disappointed, I wouldn’t recommend to purchase the heated plate as it is.
