Today I connected the extruder to a ground wire as recommened by Tiertime.
Before connecting the wire I measured the continuity / resistance between the extruder (screw) and the motherboard screw(s) and it showed continiuty.
So there exists a ground connection without the additional wire and my question is: Is this connection fading (maybe because of axis movement) or what is the reason for the additional wire, higher wire thickness?
