Anyone using
eSun PLA+? I not sure if I got the setting right. The support literally
being fused to the print. I have easy peel check box ticked.The temp is within manufactures suggested
range. Currently, I having to grind off the support with a dremel. Ideas? TIA.
This looks like the raft, not supports. I use eSun PLA+ and I don't have any issues with it. I use 214 degrees which is a bit higher than the default for PLA in Cetus3D. I used to have issues with the rafts but a later version of Cetus3D fixed that. Now my rafts pretty much pop right off with very little effort.
Sorry, about the terminology. I actually have I have
the same problem with both rafts and support. The last thing I
printed (picture in the post) just happen to need only a raft. I printing
at 216 and I'm using the newest version of the software. I'll try lowing
the temp to 214 and see if that makes a difference. Thanks for the help.
