FYI
Here you can see the result after several test from 240-270 degrees.
FYI
completely blocked? The nozzle can work without the cap.
I think there where to much back preasure and the filament get out between the metal and the plastic part.
You ran carbon fiber through a brass nozzle and are surprised it failed?
No Iam not. Just wanted to share. This is my first 3D Printer and experience at all. So I think I can make any mistake I want. And even a brass nozzle should last for some time, I gues.
Yeah it should last a few hours.. and even then the tolerance of the nozzle should be all thats effected during that time. Cetus needs to make a steel nozzle!!
[quote][size=2][color=#999999]sanshyuum post at 2017-4-4 02:17[/color][/size]
Yeah it should last a few hours… and even then the tolerance of the nozzle should be all thats effe …[/quote]
Yeah thats for sure.
