Whe selecting custom material I dont get the ADD option , also tried running the exe and does tha same .If I try to export one of the defaults and change the name , then import it , nothng happes, I would like to change the settings of temp and others for a particular PLA Fil.
Any comments appreciated…
UpBox+ with UP_Studio_x64_2.6.49.627 on win10 2004 USB connected.
Replying to my own post, following some very good instructions from a person in this forum , I manage to get the material customized to my requirements.
Now somehow there is no way I can print PLA without raft, the priming line is perfect and sticks very well, but as soon as the actual print starts the head to bed distance increases to a value almost double the card size , I tried ofsets but I do not understand how to use them…
just adjust the nozzle height value (at maintenance tab) until you get good result.
base on description you should increase the value a little bit (eg 0.2mm)
