After updating UpStudio, my UpBox printer will no longer adjust the extrusion temps to what I set them to in the custom material settings. If i set them to 200Deg C, it will still heat up to 270. Custom settings will also only allow me to select a .5mm nozzle. Its as if TierTime is forcing me to use their up filaments. Please someone tell me I am wrong and if so how can I fix this problem. The printer is useless to me like this.
Updating software may result in lost of stored print profiles (depends on version).
If you are limited to select 0.5mm nozzle, this may due to the custom profile only has 0.5mm nozzle setting.
