Basically I want to slow down the XY movement speed while not extruding while keeping the XY speed during extrusion high. There is no option for “x/y axis movement speed” like there is in Simplify3D, so I went into the settings for my custom plastic and adjusted the “contour print speed” and “infill print speed” for the “fine” setting to much higher values (see pic).
I expected the time for printing would go down a lot since print speeds were changed so much, however the print speed did not change at all when compared to printing my part with the default “fine” settings. Can someone please explain why the printing time didn’t change at all after dramatically changing the speed settings? I’m at a loss for why the print speed didn’t go down substantially.
