janp
January 17, 2017, 5:14am
1
JanP 2017-1-17 05:20 edit
I'm running all Linux which I know is not supported. So I've installed Windows 10 in a Virtual PC (QEMU/KVM).
Installation goes well, but when I start the application, I get anerror message to update OpenGL and to check the graphics card drivers
Currently the display in KVM is set to 1600 * 900. The Video controller is set to have 4Gb Memory, through the Redhat QXL driver.
What system environment does Cetus Studio require to run?
system
January 18, 2017, 2:02pm
2
The Windows software require display card support OpenGL 2.0 or above.
The Mac version need OSX 10.10 or above
janp
January 18, 2017, 10:34pm
3
Thank you Jason
I'll look in to this further this weekend.
janp
January 23, 2017, 3:42am
4
For anyone running LInux, you can get Cetus studio to run under Linux (kind of) through VirtualBox.
The issue I had, was an age old problem with the Guest Additions installer. It fails to add three register keys that advertise the OpenGL features.
More information available in the ticket below
https://www.virtualbox.org/ticket/12048
Sadly this issue was discovered 3 years ago, solved 18 months ago, but are still there in the latest 5.1.14 version of Guest Additions.
jblat
June 27, 2017, 9:11pm
5
@page { margin: 0.79in }
p { margin-bottom: 0.1in; line-height: 120% } <p style="margin-top: 0.05in;margin-bottom: 0.05in"><span style="color:#000000">No
go through wine then either?
I
am seriously considering this printer but if i cant get it to run on
linux its a no go…
Is
there any published source code or is it all closed source?
VirtualBox
is a pain in my experience and the performance leaves much to be desired…
Jon
cmeyer
June 27, 2017, 10:35pm
6
You should be able to use https://github.com/UP3D-gcode/UP3D with the printer as shipped, alternatively you can replace the CPU with the tinyFab CPU which runs the open source smoothieware at which point you can use lots of different slicers, etc
c6tk
October 14, 2017, 9:02pm
7
But what about WINE (Windows emulator)? Does it work?
