Avoiding jitter when printing walls
The printer vibrates very fast to fill some walls.  What are the threshholds to avoid this?  I mean, what thickness should I make walls for it to just print 3 or 4 smooth layers.  Or is this even possible to control?  Thanks.
metaka726 2017-6-15 21:22 edit
I should also add that when it jitters in order to fill a thin wall cavity it sometimes doesn't succeed at touching the inside of the outer wall layers.  I would really prefer it to just print thin walls solid.  I'm using the default nozzle size that ships in the printer.
