Not a problem! Settings are below:
Nozzle Diameter - .2mm
Extrusion Multiplier - 21
Extrusion Width - .24 (standard 20% larger than nozzle diameter)
Retraction Distance - 40mm
Retraction Speed - 8000mm/s
Coasting - 1mm
Wipe Nozzle - off (can still do 3mm-5mm for .4mm anf .6mm)
Layer Height - .05mm
Top Layer - 6
Bottom Layer - 5
Outline/shell - 3
First Layer Height - 90% will help stick to plate better
First Layer Width - 120% - will help stick to plate better
First Layer Speed - 40% - will help stick to plate better
Raft Layers - 5 (makes it easier to separate in one piece since it's so thin)
Raft offset - 1mm
Separation Distance - .15mm
Raft Fill - 100% (again this helps make it easier to pull the print off)
Infill - 10%
Outline Overlap - 25% will make sure it sticks to the walls properly
Infill Width - 115% - helps keep the infills mroe stable and solid
Minimum Length - 1mm I like to have infill even in smaller areas just in case
Temp - 205 first layer
          - 196 for all otherr layers
Fan default 100%
Print speed - 30mm/s Better for detailed models and to prevent under extrusion
Outline - 60%
Solid 80%
Support - 80%
Movement speed - 150mms
Z Movement speed - 16.7mms
Filament diameter 1.72mm I always tell people that it's important to measure the thickness for your filament in 3 spots then average them to get a final number. just putting                                             1.75 may not give you accurate extrusion. Even if they say +or - .05mm it's not always the case.
Allow Perimeter overlap - 30% This will help in areas that it's too thing to fill but too thick to consider a thin wall. 20% - 30% is usually what I always use.
PS: I set my Z offset to be about .5mm from the plate, then use the first layer height % to adjust if it's too far from the plate.
