Could you see the difference between the 2 Iron Thrones printed on Cetus? (Our new printer that will be on kickstarter soon). Left one: printed using a 0.4mm nozzle at 0.15mm layer thickness. Right one: printed using a 0.2mm nozzle at 0.07mm layers thickness. Spray painted. The cube is a 20mm test cube and the models were scaled to about 7.5cm in height.
We are trying to optimize printing conditions that use 0.05/0.07mm z-resolution printed by 0.2mm nozzle, so that customers could get HD prints right out of the box.
I found in the online manual on this website (under FAQ) other info that contradicts the Facebook info about nozzle size and layer heights. The manual lists this:
0.2 mm nozzle is for layer heights 0.05 and 0.07 mm
0.4 mm nozzle is for layer heights 0.10, 0.15, 0.20 and 0.25 mm
0.6 mm nozzle is for layer heights 0.30, 0.35 and 0.40 mm
Is that the correct info? If I use 0.2 mm nozzle and 0.10 mm layer height I presume the model will be overextruded/stuffed?
