Hi, my Cetus prints fine at 0.4mm but with the 0.2mm nozzle it clicks and doesn't extrude very well at all, I can't print with the 0.2mm nozzle (I have two of them, the tolerances are actually quite poor because there is a big size difference in the holes between the two 0.2mm nozzles, but anyway).
The filament is clearly being pushed through too quickly - Cetus can you please fix asap!!
I'm trying different prints and it seems it clicks more at beginning, then it stops for a while. Last print i left little cetus alone printing, because it wasn't clicking anymore but when i came back... big sad fail :(
If you know for sure your nozzle is clear, you may want to increase the temperature on the nozzle by a little bit. Be sure about the nozzle though. Even a new one can be blocked by metal burrs. I had two new ones create for this problem and then a third nozzle that was definitely not clogged ended up working.
You probably know this already, but you'll have to print at a slower rate with a 0.2mm nozzle than with a 0.4mm one. I usually cut my print and infill speed in half as well as raise my temperature a bit when I use a smaller nozzle. I usually only go with a 0.2 when I want to print layer heights of 0.1mm or smaller.
[quote][size=2][color=#999999]vegasracer post at 2017-5-30 18:28[/color][/size]
You probably know this already, but you'll have to print at a slower rate with a 0.2mm nozzle th …[/quote]
